Electrical Load
Jtsky
FLA
I am curious how the load on your cars electrical sytem changes depending on how you wire your amps. Lets say you have an amp that does:
250 wrms @ 4 ohm
or
400 wrms @ 1 ohm
The first thought that comes to my mind is more wattage = more load on electrical system, but for some reason I am doubting this. Can anyone help me out here? Is it true that either of these setting would have equal load?
That's a good question, and while you're on the topic, i've always wondered why it's possible to set amplifier gains correctly while no speakers are connected to the amplifier.....? Especially when using a dmm to set them.
I think i understand why it works ok with an o-scope, since clipping is a function of the amplifier's pre-amp, and not the actual amplifier itself, but i don't understand how you can use a dmm to set gains with no speakers connected, if the power's going to be completely different with speakers connected.
Because voltage is a constant variable in this case, and the amperage changes when the resistence decreases. So, when you set gains with a DMM, your setting at a certain voltage that will remain there. Whereas, when you add a resistence, that detirmines how much amperage. Remember, Power is an equation with all three things considered, Voltage, Amperage, and resistence.
the lower the impedance load the more current it will draw from your amplifier. if youre worried that your current electrical system is not up to the task. find the continues amperage of your alternator and add the fuses on the amp, if the fuse amperage exides the alternator output in amps, then its time to up grade your alternator or just rund the amp at a higher impedance load. that way you dont put too much stress on your electrical system.
i would not set the gain of an amplifier without a load, use ether a pasive load or a reactive load. for the simple fact that most amp use fedback from the amplifier output to the voltage amplifier, if you dont have a load then the adjustment made could be inacurate.
What would be the rule of thumb number, of how many watts you can run with an 80 amp alt? I know that there are many variable, but could you give an estimate.
Pretty sure it's amperes x voltage = wattage
not sure how efficiency factors in, tho
as in, i'm not sure how to figure out how big a class d you could run vs a class a/b vs a microwave, but i guess it's a rough estimate!
true a healthy electrical system should run in aroun 14.5v
bringing the total wattage a little higher then the one i calculater earlier.
you should check your system and do the math for your vehicle.
BUT, remember that your vehicles electrical is pulling amperage as well. Your amp also will not always pull maximum amperage.
On a stock alternator of 80A, I would say devote 25-30A of it to stock electrical needs.
so
65 amps x 14.5v = 942.5 watts
and that is the most I should run if my electrical was totally healthy and putting out 14.5 volts?
yep!, if you run anything higher youll start getting things like head lights diming interior light diming. and on extreme cases your alternator would go out. since its powering everything in the vehicle including charging the battery, runing the ignition system and runing your stereo system.
Jtsky
Jtsky
FLA
yacob.naif
