I am having what I believe is an electrical issue that I cant figure out. Ill start by listing my setup.
kenwood kvt-617dvd
1 jl 12w6v2 d4 wired parallel in a ported box
jl 500/1 v1
4 ga power and ground. both directly to the battery
50A fuse 18" away from my positive battery terminal
Okay so the issue I am having is my amp stops working when I turn up the volume. It will come back on for a few seconds and then shut off again for 10 or 15 seconds. It will continue to produce bass at very low volumes, but when I turn it up I will get a few seconds of bass and then it starts acting up so I shut it down out of fear of burning something up.
I set up the amp according to jl's website using a 50hz tone and a dmm to 31.6v. I am getting 14.12v from my alternator.
The thermal light not coming on and neither is the low ohm warning light. The power light stays on. The amp does not feel warm to the touch.
Now I dont claim to be an car audio expert by any means, (otherwise I would be answering questions like this instead of asking them) but wiring an amp seems to be pretty straight forward. Im also pretty sure that with this setup I WONT get ear drum shattering, smash every system at competitions, brown note busting bass. But...... I should at the very least be able to slightly irritate my neighbors and not get laughed at by the kid in the cavalier with two 12" DUAL subs in the neon lighted box and the 500 watt lightning audio amp.
I will be looking into doing the "big 3" to see if that helps. Im honestly not looking forward to it due my battery being in the trunk and trying to run 1/0 ga wire from my alt all the way back but I will if I have to.
I know the amp will shut off if the voltage from the battery drops too low but I have no idea how low it has to drop till it shuts off. I would think that if I am getting 14.12v from my alternator that low voltage is not really my problem. But again Im no expert.
I will try to answer all questions the best I can. Any ideas would be greatly appreciated.
kenwood kvt-617dvd
jl 500/1 v1
