k_schutte
- Thread Starter
- #16
Well, as of right now i don't do any shows but i would like to hit up a few a year atleast. adn the reason for wanting more power... THAT is a dumb question, why would you NOT want more power if it is going to cost about the same as if you where to stick with less power....Better question. Why you wanna do this. Do you compete. Are you going for any world records. How many shows do you hit up during the year... Seem like a waste of money and time just to go higher in voltage.
MechMan is where i am getting my alt. that is about $550 with an ext. regulator. So now i can either run it at 12V and spend a bunch of money on 4+ 12v batteries or spend a couple hundred less on 2 16V batteries and have more power... The sub is an APX18 and amp is an XXX-6500D which will be running at 1.5ohm....
I can get the alt/reg and 2 of the D1000's for under $1K so the whole or i could get the same alt/reg, run it at 12V and buy a few Kinetiks for $800~ and have more money into a setup with less power in the end. Plus, IIRC an amp actualy has less current draw at higher voltages....
