Electrical Help
dross93ranger
I am currently running 2 12" Type R Subs (SWR-1243D) powered by a Power Acoustik BAMF 4000-1D (Please don't give me **** over the amp, it serves me well).
I had the subs wired to 4 Ohm so I was pushing around 1200W to them and the factory electrical handled it with ease. Today I rewired the subs to 1 Ohm so I am currently pushing around 2200W to them (I however will probably never turn the gain that high though). The stock electrical cannot handle this. I watch my gauge drop from 14V to 9V and my cd player turn off and a few seconds later turn back on.
I know I need to do the big 3, but I feel like that alone will not fix the issue. I'm guessing I will need to get a new alternator as well. Is there anything else I need to do or is that about it?
BTW if it matters, it is a 2000 Astro Van with the 4.3l
Big 3, Alternator, batteries.
Although I wouldn't exactly count on that amp producing 2200w especially being fused at 120A (3x40A), Ohm's law says it's overrated //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Batteries do not fix voltage drop because they do not sit at 14V so they are of no help until the system voltage drops to their resting voltage. The system voltage dropping from 14V to 12V isn't a big deal to the components (they can handle either) but if you don't have the battery bank to hold it at 12V (or approx resting voltage) it will drop lower which is where low voltage damage comes in. Further more even if you have the bank there to hold the voltage, you're still neglecting the alternator which clearly cannot handle the load and will prematurely fail.
^^^agreed.
additional batteries can help reduce voltage drop, to a point, but you may run into charging issues. i don't generally recommend multiple batteries for this reason. i would test the alt and battery to make sure they are working properly before upgrading anything though.
dross93ranger
dross93ranger
Maysville, KY
dross93ranger
