4 channels 6 coaxials
D.SKATERBOY
i need help im trying to design the perfect system from my car when i get home from deployment
tell me if this could work :
Power Series 4-Channel Class A/D Car Amplifier
RMS Power Rating:
4 ohms: 250 watts x 4 chan.
2 ohms: 250 watts x 4 chan.
1 ohm: 250 watts x 4 chan.
Bridged, 4 ohms: 500 watts x 2 chan.
Bridged, 2 ohms: 500 watts x 2 chan.
Dynamic Power Rating:
4 ohms: 290 watts x 4 chan.
2 ohms: 290 watts x 4 chan.
1 ohm: 290 watts x 4 chan.
along with 6 to 8 of these
6" x 8" Type-R Coaxial 2-way Car Speakers
Power Handling:
Peak: 600 watts per pair / 300 watts each
RMS: 200 watts per pair / 100 watts each
New style grille offers full woofer protection along with a unique new design
Multi-Layer hybrid fiber cone delivers a really strong bass response
High Amplitude Multi Roll (HAMR) Santoprene rubber surround provides consistent, extended cone movement
1" Swiveling silk ring-dome tweeter produces smooth highs
High-Density polymer frames
Frequency Response: 63-29,000 Hz
Sensitivity: 89 dB
Top Mount depth: 2-9/16"
thanks in advance
read around on some threads here, there are some good ones in the Speakers section. do searches for "front stage".
the short answer is yes, that amp can power 6 or 8 pairs of those speakers.
whether or not it's a good idea or will sound decent is a different discussion. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
it helps to know what vehicle we're talking about.
ALOT...haha, basically those coaxials your looking at are not a natural shape and will not have a natural response, 6 1/2 round speakers sound better...the component portion means your get independent tweeters and a set of real xovers not that little capacitor they put between the high and low drivers on a coaxial. Also the tweeters being independent of the bass driver means you can mount/angle them differently....while it is best to place your tweeters as close to the mid bass as possible, like a coaxial does, high frequencies are directional and your ears a better able to tell that the sound is direct slightly away from you or toward your feet or what have you...
D.SKATERBOY
D.SKATERBOY
chicago Il
keep_hope_alive
michigan born
    May 14, 2026
michigan born
    May 14, 2026
