Electrical help
i moved my power and ground runs an cut about 3ft off of each run. it definetly made a difference. drop to 12.5 from 14.0. if i get a mla or a voltminder will i still drop 1.5 volts from where it is set at or will i still drop to 12.5?
how are your wire connections made? Did you crimp them or half *** bash them with a hammer? maybe you have some loose connections that are causing the voltage drop.
this is what happened with me :\ it didn't work out, so i end up soldering it to the terminals. it helps a lot.
my buddy is running mid 150's with 2 12" hcca and 2 of the gp3000pro's in your sig as a daily driver in a midsize gm sedan with a 220 amp alt and 2 group 31 standard batts and he has no issue so its prolly a wire loose somewhere. but he is also running 2 runs of 1/0 wire.
Checked all my connections and nothings loose. I did use a hammer btw but all my ring terminals are on the wires secure. Going to have my alt checked tomorrow.
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
Crownvicon28s
