electrical for audiopipe ap30001d?
yea dude id be more than happy to go up against you.
have you metered? becuase on music with one 3000d, and as you say, not getting 3000w, i was doing a 147.x sealed up on STOCK electrical, with the window down it was a 151.x.... ill meter tomorow get vids.
again, the whole amp draw thing. say it DOES draw 300a. that'll drain my battery pretty quick huh? that means your alt will recharge it, correct?
weather the alt is 105a like my stock one, or a 300a, its still going to recharge it. the 300a will obviously charge it faster, but either way theyll get charged.
obviously my amp is pretty **** effiecient, becuase its not going below 12v with the car on @ full tilt.
as i said, i dont know what imp rise im actually getting, but ive heard many other setups with 3kw, and i know for sure im not "only" getting 1500-2000 out of my amp. say i add 3 more batterys, its going to help me keep my voltage higher for longer before they drain and the alt kicks in and recharges them, but just becuase i only have a single batt and 105 alt doesnt mean i cant hold 12+ volts at full tilt, thus getting my power.
robin has like 6 batts (maybe more) and last time i checked has his stock alt in the neon (which i think 95 or 100a (smaller than the mini alt) and hes pretty loud and if u wanna go up against him with ur 18, be my guest becuase he will hand you your ***.
and i specificially remember talking to him a few yrs back about HO alts and he feels the same way i do, in which if u have one 300a alt its not completely a waste, but IMO its not worth the money, becuase if your amps are drawing more than 300 amps, its sitll gonna have to wait to recharge. only way i see that they feasible is if you have 4 300a alts, this way you have 1200 amps recharging your batts........ but i mean from 100a to 300a, for the money its not worth 200 amps if your amps are drawing more than 300 amps to begin with... IMO you're better off spending your money on more batteries.
not anyones, his. if he is going to run his mouth about my setup, then he should step up and see how it does.
true, but when i had my sundown, through testing i found i was pulling about 300amps at full tilt so if his is doing 3k, then it should be pulling about the same
ok i never said it wasent drawing 300a at full tilt. even if it is, how does my voltage stay AT 12v (at the lowest) at full tilt? care to explain?
i never talked trash you started about the whole amp thing...but i can bet im louder.....
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif WOW @ the OP you really dont have an freaking clue what so ever do you? ypu put up an vid of you getting 3kwrms playing music like you think you are, then id personally fly to where ever you are and RECORD me kissing your ***, and put it on this site and youtube. hell id make it even more sweet for you. id give you 2 of my 15001ds!
i dont understand what you're trying to get across. please explain.
just becuase im at stock electrical doesnt mean SHIT. you guys are ****ing brain washed with HO alts.
last time i checked, an alternator only CHARGES the batteries.
obviously, at full tilt, my alt/battery will stay at 12v...
if your talking to me. my point is No way in hell you are getting an constant 3kwrms like you think you are. and your **** sure not getting 3kwrms playing music thats an **** fact. anyway what size is ur box?
about 12 cubes net
i never said i was getting it CONSTANT...refer to page 2 where cj407 explained that with imp rise on music its not constant, its always changing. there for its going to fluctuate up and down, so i may not get 3kw CONSTANTLY, but im confident im getting close to 3000w rms on average. i dont give a shit what you think.
im at/above 12v at all times, and by what jake has rated AND TESTED his 3000ds at, im getting the same power.
OMG. WHAT DO U KNOW??!?!?!
http://www.soundsolutionsaudio.com/forum/index.php?/topic/30180-uniform-amp-clamp-test/page__p__540899__fromsearch__1entry540899
jacob himself tested the 3000d @ 12.1 volts, 1.14 ACTUAL impedance, and got 3280w rms.
therefore, even a fifth grader could understand that if im at 12v or more AT ALL TIMES, and given im at 1.14 or less ohms, im getting AT LEAST 3kw.
now, i havent clamped to find my ACTUAL impedance, but its at .5, so i cant say what its actually at, but that doesnt give you the right to guess what it is and assume thats just what it is either.
about 12 cubes net
ok mr 3kwrms. but anyway screw all this arguing crap i have a ? for you! by reading what you posted in this thread, you do not believe in buying HO alts, then why the hell you make an thread asking about what type of electrical to run 4 3000ds? why not just get an shit load of batteries? basically tahts what your going to do anyway since you dont believe in ALTS. so basically your thread is pointless and you had your answer to your qestion before you even asked it?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
well ive got an answer for you! (***)
i dont see anything in post 1 mentioning an alt?
i was mainly looking for replies on how many batts to run, and really only looking for people that have the amps/have ran them before.
and i still believe that a 300a alt isnt worth the money, maybe a cheaper one for more common cars but for a mini cooper its deff not worth the 500+ for a 180a amp alt, thats 80 more amps that stock for 500? if ANYONE pays that, im sorry, but you'd be classified as a dumbass, plain and simple.
who gives a **** if it was said in post 1 or post 20 bottom line you made it clear you wasnt buying an **** alt. man honestly its not even this freaking serious, at the end of the day, what your at 147-48dbs and thats playing music maybe, Still Quieter than, hell my Last 2 installs. shitt for your ? just go with a bunch of powermaster 3100s
and its also in an undersized box in one of the smaller cars on the road with not alot of room, and again, since u say its a big deal, on stock electrical and "im not even running 3kw"
so what until i get more batts and some real power and we will see how it compares to your BEEFY kenwoods LOL
New system
1.)12 12" kenwood KFC-W3011's
2.)8 Audiopipe AP-15001D's only have 5 right now!
3.)1 funky *** box tuned low
4.)Maxxsonics Maxx-Link
{Numbers}
TBA!
orangecounty1
orangecounty1
Tampa, FL
PioneerSPL1990
vegang
vegang
