Gain
No. Even the head unit itself has a point of clipping. If you don't have a 'scope, your best bet is to set it at 75%-80% of max volume and go from there. Gain is a sensitivity. It matches your amplifier to your head unit so that you're able to use your full volume scale. Example: If your head unit goes to 50 I wouldn't go above 38. If you set your gain too high, it will reach full power before level 38 which in turn will create a clip in the sound wave if taken too far. If it's set too low, your amp will never make full power at the given volume level (38).
01tundraon6s
01tundraon6s
Dallas
dB-SPL
