Electrical Dilemma
Bumpin' Goalie
Magic 8 Ball
So first off, i DID use the search button. But almost every inquiry had a stock alt of 110 amps or more.
My vehicle has stock electrical through and through. 80 amp alternator and a stock (yet decent) battery. Its a 2008 Suzuki SX4.
I will be running an AQ1200d @ 1 ohm and a Diamond 2 Channel @ 4 ohm (150rms total) as soon as tomorrow.
Power is high count 4 gauge, grounds in the same. I'm not overly concerned with replacing the 4 gauge because the amp will only need to produce ~1000rms to suit my application.
I want the Big 3 to solve any problems. Trying to avoid spending money, because, frankly, i have none.
Let me know what else i might need. Be gentle financially please //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks.
you will be fine
i had a civic with 2 rockford bd1000, powering 2 9512, a rockford 4 channel with 3 batteries, all on stock alt with big 3, never had a problem.
did 148's all day
So, everything is installed, and well, no dimming headlights, no dimming interior lights, amp working @ decent capacity, etc.
Seemingly no major voltage drop running on stock 80 amp alt and stock batt, no Big 3. Is this a stroke of goodluck? or? i'm going to try to grab a voltage meter to double check everything.
So' date=' everything is installed, and well, no dimming headlights, no dimming interior lights, amp working @ decent capacity, etc.
Seemingly no major voltage drop running on stock 80 amp alt and stock batt, no Big 3. Is this a stroke of goodluck? or? i'm going to try to grab a voltage meter to double check everything.[/quote']
No, like we all freaking said, you'd be fine and you are. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Read. Read, read, read.
A few people said i would be ok, however the majority (not just this forum) were screaming i'd need big 3, batt, and blah blah blah.
just trying to be thorough. thanks again for all the help. especially l4yfr4me.
Bumpin' Goalie
Magic 8 Ball
Bumpin' Goalie
TN & Travel
Bumpin' Goalie
