Eeek, odd flexing...
xpl0it
everywhere
The right side of my box, the far right panel flexes about an inch or more (port opening). How can I fix this? Should I tear the carpet off my side of my box, get another piece of MDF wood, and glue and screw it to that flexing piece for extra support? It looks as if the wood will break it's flexing so much, lol.
You should drive over to pike township and let me um...help you out //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
What school do/did you go to? I'm 07 at Brebeuf.
i graduated this year at carmel high school. What are you doin tonight? Do you know mark comparato at brebeuf?
Yep, pretty decent b-ball player. Tonight I'm finishing some designs and gettin up early to get my senior photo taken FTL/W
run a piece of threaded rod from the inner port wall to the other side of the box. i wouldn't put any type of bracing in the port though.
The inner port wall doesn't flex, just the side of my box. You PVAudio, you want to meet up at the HHGregg on 96th street tonight? I'll show you the L7s and maybe you could help me figure a couple things out.
Maybe tomorrow, but I have zero gas, zero energy and zero money = I have to finish these designs then go to sleep. Lol you shoulda asked me yesterday, I was up at claddagh or wte that irish place is by hh gregg.
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
It sounds like the remote is wired to the interior courtesy lights. Those lights come on as soon as you remove the key from the ignition. Try...
xpl0it
xpl0it
everywhere
PV Audio
    May 16, 2024
    May 16, 2024
