If you are implying that 2 2-channel amps will always have more power than one single-channel amp you are wrong. It just depends what amp you get. If you list what subs you have then someone can suggest an amp for them.POWER?
Im implying that two 400 watt amps have more power than one 400 watt amp.If you are implying that 2 2-channel amps will always have more power than one single-channel amp you are wrong. It just depends what amp you get. If you list what subs you have then someone can suggest an amp for them.
if they are 4 ohm subs, you would need an 800x1 @2 ohms, not at 4. And yeah, you can pick up a alpine 850 (800@2 ohm) for 235 in the classifieds...
if they are 4 ohm subs, you would need an 800x1 @2 ohms, not at 4. And yeah, I know what they cost. They arent that much. you can pick up a alpine 850 (800@2 ohm) for 235 in the classifieds... I sold a 900x1@2 ohm amp for less than 150 a couple days ago. BNIB...
you can do better than 2 bridged amps, and probably cheaper too
2 Dual 4 ohm subs will wire down to 1 or 4 ohms. What are you talking about? //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
ANSWER PleaseI can't wire my subs 2 ohms. Either 4 or 1. There is no question here about comparing costs. I have the subs and I have the 2, 400 Watt amps. So My cost is ZERO compared to anything else.
Yes in the year I have been here I have spent a lot of money and learned a lot but I dont know everything. FOR EXAMPLE what I don't know is if its acceptable to wire my 2 amps to my 2 subs. If its not acceptable then tell me that. If it is acceptable then tell me how to do it. One per sub or strap them.
Thanks.
He posted having two Dual 4's, you know subs..........READ the thread.His sig says they are dual 2 ohm subs. Each of those would be wired to either 1 or 4 ohm. togethor, that means 2 ohm or 8 ohm. thats what im talking about. you know, how you wire subs...//content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
