dual amp hook up
pioneer amp is now running at a higher ohm load mostl likely, so right now you aren't really pulling any poewr from it. Also mixing sub types is usually not a good idea. Occasionally can cause cancellation, which could be your problem, but most likely not. Those 2 subs are extremelly different, so i would recomend getting another of the same so you have a pair of the same subs.
projectpatza
projectpatza
rochester NY
nosaj070
