dual 4 ohm voice coils
  • 1
budnik-- call the voice coils on your (dual 4ohm sub)
voice coil #1 and voice coil #2
wire the plus from voice coil #1 to
the plus of voice coil #2
then
wire the minus from voice coil #1 to
the minus of voice coil #2
this is called parallel wiring a dual 4 ohm sub
for a 2 ohm load
then
wire the plus and minus from your amp
to voice coil #1 plus and minus
for a 2ohm load to your amp
The Biden administration on Tuesday backed down on a controversial proposal to direct the IRS to collect additional data on every bank account...
31
6K
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Budnik
Budnik
Sullivan, Illinois
    May 18, 2024
    May 16, 2024
