jbl bp 1200.1...?
  • Thread starter Unregistered
  • Live activity
  • Replies 2
  • Views 943
U
Unregistered
Guest
ok...this post is kinda related to one i saw earlier about wiring a jbl amp.
the bp1200 is a mono amp capable of handling a 2 ohm load right?
i was planning on starting my system out by running one sub with the amp(600 rms), then when i get more money, i will add another sub. i want to wire the subs to get a 2 ohm load, so as to get 600 to each sub. what kind of sub will i have to use? single voice coil? dual voice coil? 2, 4, 8 ohms?....please help me out...
p.s.-i was planning on using the infinity perfect subs(single 4 ohm coil)-would these subs be ok for the setup, and IS IT POSSIBLE TO USE A 4 OHM SUB, and run it with a 2 ohm load(which i want to do).....
thanks a lot guys..
peace;)
Yes, the 4 ohm SVC Perfects will work quite well for what you are considering.
To achieve the 2 ohm mono load at the amp, you will need to wire your subs in paralel.
Have a look at the link below for a pic on how to do this.
attachment.php
take it easy,
-zane
unregestered-- you can use either a svc sub or
a dual voice coil sub.
if you use a svc sub it will have to be a 4 ohm voice coil sub
to get 600 watts from your amp then when you get more money
you can get another svc 4 ohm sub ( same brand) and wire
both subs in parallel for a 2 ohm load to your amp
so each sub will be getting 600 watts each ( 1200 WATTS TOTAL)
( just make sure your subs are capable of handling the power)
or
you can use a 2 ohm dual voice coil sub wired in series for a 4 ohm load
to get 600 watts from your amp. then when you get more money
you can get another 2 ohm dual voice coil sub. (same brand)
and wire both subs in series/parallel for a 2 ohm load to your amp
for 600 watts to each sub. (1200 WATTS TOTAL)
(just make sure your subs are capable of handling the power)
HOPE THIS HELPS
Guest
ThxOne
    Aug 15, 2026
TechGuru88
    Aug 10, 2026
