dual 4 ohm voice coil
You already have the answer but you dont want to listen. What is "bridging the subwoofers"?
You have two dual 4 ohm drivers. Wire each to give you a 2 ohm load and hook each to ONE channel of the amplifier. PROBLEM SOLVED.
Exactly why I asked this:
What is the RMS output of your amp?
1.) Each channel (unbridged) at 2 Ohms.
2.) Bridged at 4 Ohms.
3.) Bridged at 2 Ohms.
So, OneFalseMoce, can you help us help you by answering this?
[edit] what subs do you have?
hey ska you can **** off, if you dont want to reply, hit the "back" button and have a nice ****ing day you prick.
I got it figured out, thankk youu have a nice day
You ask a question, someone answers, you ignore the answer as its over your head (or you simply didnt like it) then get all pissy nobody is answering. If you are too nooby to even understand how/when someone is answering your question, take it to a pro to install, or risk 'frying' it, but keep your attitude to yourself. Its not his/our fault you can't even recognize a legit answer when you see it.
What is the RMS watts of your amp for the following three?
Bridged at 4 Ohms.
Bridged at 2 Ohms.
The Biden administration on Tuesday backed down on a controversial proposal to direct the IRS to collect additional data on every bank account...
31
6K
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
onefalsemove
onefalsemove
Kansas
skadude016
    May 12, 2024
Brendon Jenness
    May 11, 2024
