Dual 15" SP4 Silverado SS Build
Delay on box, my original design wasn't good enough. Got 9 cubes total but if I do an L port it would be about 3.8ish each after displacement and port. I can do aero ports but they will be pointed at doors and not at the roof because of length. I got 34x18x22-28 depending on volume needed for the set up. Any suggestions? @pro\-rabbit ; @Buck ; @double 07 ; Power bass 5k for power and 32 hz for tuning
Update. Doing 2 pairs of comps upfront. CDT audio 61HDs and morel maximos. I know its ****** to mix things up but it will be matching down the line. PS sorry for the slow build 60+ hours a week doesn't leave me with any time
Box pretty much built just building the false floor/platform it sits on and deciding on how to strap it down. 65+ hours a week between my jobs doesn't allow much work. Couple other little stuff like deadner and I got a apline 9887
I'll send you some pics this weekend of the box and the platform, also got a set of digital design B1s to match with my anarchy's that I'm waiting on
//content.invisioncic.com/y282845/emoticons/bigwave.gif.16324171cad2db62cf4f16568b038478.gif
121
441
943
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
891
Silverado SS
Shake Pound and Rattle
Silverado SS
Cleveland
gckless
    May 31, 2024
    May 24, 2024
