integra88
Been There...Bumped That!
I have always done the "twist and tape" myself. I have a bad habit of changing H/U's on a way too regular basis.
The thing about tape is true.......what should you suggest I do to the big 3 wires under the hood that is near my exhaust? ATM I have wire loom over it with black tape around the loom, I also have it taped away from the exhaustI use butts on headunits. I can sit in here at work/home and wire it up and walk outside and plop it in. If I solder I use heatshrink. Tape sucks. From the heat sometimes it starts to lose its stick and unravel.
x2.....while at the shop for customer is butt-con....my personal stuff or friends on my own time....solder/heatshrink.....looks alot neater and not coming apart and zip ties to hold it together.....twist and tape I will NEVER do....that is very lazy and IMO if your going to do it that way.....have someone else do it for you or do it properly.....common sense to avoid any future problems....a little moisture could ruain your day //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gifI use butts on headunits. I can sit in here at work/home and wire it up and walk outside and plop it in. If I solder I use heatshrink. Tape sucks. From the heat sometimes it starts to lose its stick and unravel.
Then use some of these:I have always done the "twist and tape" myself. I have a bad habit of changing H/U's on a way too regular basis.
