Do i need an electrical upgrade??? 06' camry
tuskilla
im going to be running a Diamond D3 1000.1 with a RE *** 12D2, i also have 8 interior speakers, will i need to upgrade anything in my car?
Would a capacitor help out my lights that I KNOW are going to dim? ALSO is a Tsunami a good capacitor?
Cap won't help.
All you need to do is Big 3, and upgrade to a good batt under the hood. The dimming should be very minimal after that.
what battery do you suggest? and do capacitors do anything at all? or is buying one a waste of money?
also is JUST getting a new better battery going to do the trick or is my car going to suffer because i didnt do the alternator and whatever the 3rd thing in the big 3 is?
you have it wrong. the big three has nothing to do with the battery and altenator. its the wires that run to them. you want to upgrade the factory alt to battery wire, the baattery negative to chassis, and engine block to chassis all to 1/0 wire
ya i just figured that out, one more question, i can either do the 3 OR get a new powerful battery and they will do the same correct???
if so what battery would you suggest?
yes both. the big three will allow for more current flow with less resistance. the big three should be the first electrical upgrade imo. then a good battery upfront, an extra 1+ and then the high output altenator. but you wont need the ho alt youll be fine there
lol, holy shit, he doesnt need all that, a smaller deka under the hood should be fine, i dont know what size his battery is tho or i would reccommend one, i bet he could fit a 34 probably
ha no i know i was listing the order i go through until dimming stops. but yea i guess the 9a31 is a little to much i always forget the size issue because my batts stock in the trunk so it wasnt a problem as far as that. one of those are awesome tho for the price
yea they are, best deal out there
absolutely, im so glad i went with them over the knetiks. ive heard good about the kinetiks but for the price **** that. i had one 9a31 for 1000 rms and it did the job and them some. may be a little overkill, but for such a cheap price thats def not a bad thing especially since you have a little more room to go bigger later
sounds like im gunna get that battery. Then hopefully get to Audio Connections in Kenosha here to get them to do all that other shit cause i dont wanna be ****in up my car! lol
tuskilla
tuskilla
kenosha wi
audiolife
Mike Mccabe
