Do I need a 2nd battery? (Already have HO/Big3)
  • 4
CannedDog
Current Specs
2001 330i
U12 (Adding a 2nd very soon)
Singer 320 AMP
SIA - 3500
O Gauge all round
Since I plan on adding a 2nd U12 and wiring it down to 1 ohm I am worried that I will be drawing to much from one battery. My voltage is at the moment stable. I don't know if this would be a legitimate issue or not.
I would run a second battery. If you can get 2 80 ah AGM batteries, that should keep your voltage solid. You could probably get away with a little less amp hours though, I don't what options you have for a stock sized battery replacement.
I believe the biggest stock battery I can fit is an H8. Room in the trunk isn't an issue right now (yet), so I can pretty much go with anything.
If it where me (and granted I prefer to go a little overboard) if you can get 100-125 amp hours out of some good AGM batteries, I don't think you'd have any problems.
Current Specs
2001 330i
Singer 320 AMP
SIA - 3500
O Gauge all round
One bank of lithium in the trunk. Less weight, smaller, cheaper, better, and lasts longer.
555
398
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
441
639
CannedDog
CannedDog
Indiana
Bobbytwonames
    Jun 3, 2024
