Dmm -rms output
RMS output you need at least 2 things, a dmm and a AC clamp meter. Clamp the positive speaker wire coming out of your amp with the meter, and use the DMM to measure the AC voltage at the speaker terminals. Multiply the 2 values you get to get your RMS. Divide voltage by current to get your impedance rise
I thank you sir..I knew it wasnt a very hard method,and i think i do have an ac clamp as well..Thank you..I will give it a try over the weekend
When you come to test it try and roll up the volume a bit, don't just do it at max volume. That way you get a more accurate reading
audiobaun
audiobaun
USA
audiobaun
