The reason ESLs usually lack output is because they are asked to provide displacement over an extremely wide range...which it cannot support.
Im planning on using a 7' panel by 16 or so inches wide. If I used a stator spacing of .07"(70mil), I wouldnt be able to use the urethane tape. Keeping the 100:1 stator ratio intact, I would have a maximum of 7" so 2 sections. If I had 2 7" sections, I could expect 1/4" of inactive area of each side of the spacer so I lose 1" of effective radiating area. I am down to 13(2.54) by 84(2.54). This is equivalent to 7045cm^2 with 1.778mm of allowed excursion before contacting the diaphragm... I have to decide whether I will couple it to the RS390HF baffle, but either way the ESL will be placed on a 24"+ baffle. I will get a 3dB+ boost around 283hz...so the dipole effect in actuality will be doubling my displacement down low. I will not be limited by displacement down low by a longshot...although I may have issues with the resonance of the diaphragm if I want to cross at 150hz.
