video request. Sealed installs going 140+ 1 or 2 woofers only
well im picking up two eclipse 10's in a very small sealed enclosure tomorrow. custom built box, ill get up pics when i pick them up. he had 8 of them, sold me 2, put 4 of them in a lexus. he only had 2 of them hooked up in the lexus, and 'guessed' it hit arounf 135ish, sealed trunk. seats dont fold down. mine do. so im hoping i can atleast do 135-140 with the same setup, just different amp. il either be using a 1606d or a viper1200 which he has for sale for me for around 350. theyre dual 3ohm, should wire down to 1, 1.3.. not sure exactly. theyre 500rms a peice. not sure what model. but the basket on them are the same ones on Fi woofers. i have not seen any for sale with these baskets. i mention the basket because its the only way i can describe the sub. since the cones are all the same.
well if you have a pair of dual 3 ohm subs then you can only wire to 3 or .75 ohms
which might be a bit low for a 1 ohm stable amp.
but with impedance rise you might be okay.
~Magick_Man~
well if you have a pair of dual 3 ohm subs then you can only wire to 3 or .75 ohmswhich might be a bit low for a 1 ohm stable amp.
~Magick_Man~
yea they said id be ok with 1 ohm stable good for 1000-1200 watts. either way, i heard them in the lexus and fell in love with them. then found out he had 2 left for sale, with the same style box built. my jaw dropped. put up a down payment.. gonna pick them up tomorrow. hopefully ill have time to take pics, my check comes in at 2, gotta be at work at 4.
reed dollaz
reed dollaz
Ocala, FL
Jep772
