tsenfw
Just installed an an amp and 1 10" in a sealed box that I made. I'm kinda of dissappointed with the output. It will hit pretty decent if I turn it up but the gain has to be all the way up for where I want it at and I get some distortion (I think, kind of new to car audio).
Kenwood KDC-X791
-LPF at 100hz
-sub gain been experimenting between 3 to 7
-equalizer bass +2
-4 volt preamp out
Audiobahn ALUMN10Q (10")
-DVC
- 6 Ohm each coil wired parallel for 3 Ohm Load
-800 watt RMS (overrated I'm sure)
-1600 watt peak
Directed Audio D2400
-class d mono
-400 watt RMS @ 4 Ohm
-800 watt RMS @ 2 Ohm
-1200 watt RMS @ 1 Ohm
-LPF all the way up so the HU is in control
-Subsonic filter off
-Bass boost switched to highest setting of +6db
Please don't rag on my sub, I have a tight budget and inherited them. I saw a couple of good reviews of this budget amp, are they wrong? I have the gain at at least 75% and the settings turned up on the HU a little just to get it to sound right and at 100% gain for it too hit really loud (distorted). Is this common? Should my HU settings be at 0?
Could this because the amp is running under what the ratings say? I bought the amp refurbished and it looks in mint condition. I thought approx 600watts to a sub @ 3 Ohm would hit pretty hard.
Any help and suggestions would be appreciated!
Kenwood KDC-X791
-LPF at 100hz
-equalizer bass +2
-4 volt preamp out
-DVC
-1600 watt peak
-class d mono
