Disable HPF Pioneer AVH-5800bhs?
reset the unit.
I tried that and switched from using network mode to standard mode. Standard mode only has a hpf filter for fronts and rears, thankfully I can turns these off. I was concerned using it because the manual says this mode may damage speakers. I think they say that because it is intended for passive speakers with built in crossovers and if used in an active situation, without proper hpf/lpf filters speakers can be damaged...I 'm thinking I interpreted that right.
Since I'm going active and using the crossovers on the DSP I should be ok.
We'll see
Hpf set to 80hz door speakers really shouldn't play lower than that without specific design inputs ie: sealed doors, fully deadened doors, mounted...
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
338
Google can... Query DEH-X1850UB faceplate replacement.
Landshark77
Ft. Lauderdale, Fl
Landshark77
    May 16, 2024
    May 16, 2024
