different types of speakers
  • 2
LBX2G
R.I.P Camofluage
hey I just wondering if u have 2 different types of speaker in your do they cancel each other out like subs. Like if I have an MB Quart 61/2 in the front 2 doors and JL Audio 6 1/2 in the back 2 doors.
and is ther not an differnece if I amp one set of the speakers off the head unit and the others off an sperate amp. Is there not a SQ difference?
just wondering.
Interior speakers don't cancel each other out. The problem with mix matching is that you have two sets of speakers that produce sounds differently. Amping one set and not the other can cause problems at high volumes. The speakers running off the head unit will begin to distort before the amped ones causing SQ problems at higher volumes. However, unamped speakers in the rear is generally acceptable if you are only using them for rear fill.
As long as you don't overpower them, there is no danger of harming your gear, once you get a new sub so they are both the same, you will likely...
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
LBX2G
R.I.P Camofluage
LBX2G
Warner Robins
LBX2G
    May 12, 2024
Brendon Jenness
    May 11, 2024
