Did I make my box to big?
I have 12s seeing 5cu+ each after displacement. Don't let people tell you that you are free airing. If you are clipping you have one of two problems: you have a bad input signal, or you are under voltage on the amp/overpower on your subs
not clipping just starving them of port area, plus that box is too big for the power (and in general for that matter)
I should slap you for saying something like that Sac...
Ok what if I got 2 15s and made the port bigger? If that will work what 15s would be good on a budget?
No need to go with larger subs until you've tried gaining port. If you still have issues, you can always upgrade cone area/or motor strength.
Your 12s are square so they do not count in a discussion about round 12s.
burner6999- I will try and get some time later on today and help you out with this. I have been swamped and have several builds that I need to get done as well as setup my new vendor ship on another forum, so my time is limited, but I will do my best.
Thinking I will go 4th order. 3- 1 if i have the room for it. Motors to the front to help them cool faster.... and we are painting the baskets to...
Dammned that sounds good!! I usually dont eat out. But Hmm. Tempting
91
6K
Ya man. Thats No Good. As Stated. More than likely blew the power supply. I had an amplifier behind a rear truck seat and I forgot about the...
Yes, it was designed with the help of Steve at Amp Medics. They are great amps, I have many friends that run them.
Send it means play it. I didn't say send it back. I'm sure it's fine.
43
5K
burner6999
burner6999
Centennial, CO
burner6999
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
