CAT MAN 5,000+ posts
Banned
?..fixed //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I should slap you for saying something like that Sac...not clipping just starving them of port area, plus that box is too big for the power (and in general for that matter)
No need to go with larger subs until you've tried gaining port. If you still have issues, you can always upgrade cone area/or motor strength.Ok what if I got 2 15s and made the port bigger? If that will work what 15s would be good on a budget?
Your 12s are square so they do not count in a discussion about round 12s.I have 12s seeing 5cu+ each after displacement. Don't let people tell you that you are free airing. If you are clipping you have one of two problems: you have a bad input signal, or you are under voltage on the amp/overpower on your subs
