Diagnose the problem with my amp
Blue Fury
Quagmire's Chin
I have an old school memphis Belle 6-ch amp. Here is what I know for sure:
-Channels 1-4 work fine. (4x75@4)
-Channels 5 and 6 have possible the same problem, but 6 has it worse. (2x150@4 playing 80-250hz)
-Channel 5 works maybe half the time at start up
-Channel 6 never works on start up.
-Power/ground/remote is secure and is 4awg.
-Both speakers are connected properly.
-Both speakers have power from the amp (I know this for a fact)
-Neither speaker is blown, both have good coils and leads.
-The RCAs are good and both send signal (again, I know this)
-If I play a tone within range of the band pass and gradually turn up the volume to about 80% up to the volume I set my gains at, channel 5 will play a bit of static like it has a loose connection then play consistently at full output (with respect to the HU volume level)
-If I play the same tone at the volume that the gains were set at or maybe a notch higher, channel 6 will emit very little ticks of static. I want to turn it up higher to 'bring it to life' like the 5th channel, but I don't want to cause any more problems.
I've never pushed this amp hard or anything, I've treated it with a lot of care. It's got to be something in the amp but I've never dealt with amp problems before. What could it be?
first turn every pot on the whole amp back and forth very fast. This will clean them. If any are really hard to turn, they are probably bad. If the problem persists, you have a bad connection.
Blue Fury
Quagmire's Chin
Blue Fury
San Diego area, Ca
Grinder1989
michigan born
    May 14, 2026
michigan born
    May 14, 2026
