Design Request
SkronnyLonny
Trying to save space so here is what I have:
40" long
16" high
depth...want it small as possible
Just wondering what the depth would be with 3.0 and 3.5(preferred but might not have a small depth) cubic tuned to 32 hz
Sub = 12" Treo SSX
Mounting depth - 6.375
driver displacement - .2 cubic
Will pay for design. under 15" depth is preferred and that design i will take. but let me know what u guys can do. Thanks for your time.
If you need more info let me know.
\\edit--changed depth
Lonny
lol, thats only 3 cu/ft sealed if you including your driver displacement...
good luck finding someone to design you something that pretty much impossible.
with those parameters you can do 2.2 cu/ft @32Hz with decent port volume.
or
if you can do 14.75" in debt you can get 3 cu/ft @32Hz with better por volume.
ok thanks for the info, so since u got the math done...how much space will 15 inch depth get me? I guess im going to have to remeasure my trunk, or something
well i had it set at 12" depth but I am talking to chris about designing a box for me, but i also found a box built by TeamPSI using round ports that i am liking. seems like it would save space, but i dont know, I may go a different route with this and get totally new measurements
With what you have there, its impossible. If you have larger dims, then okay. Usually in box designing, if you want to limit one dimension, it's the height. Depth limitations are usually the worse because you need more volume for your port and the driver will consequently take up more space.
SkronnyLonny
SkronnyLonny
Arkansas
PV Audio
vegang
vegang
