Design Questions for : (2) 12" Kicker L5 in 14 Toyota Camry
xjake
Vehicle : 2014 Toyota Camry SE
Location in the vehicle: Trunk
Space available (Width x Length x Height): Max Space ( 40" x 42" x 18") Recommend (16" x 38" x 16")
Subwoofer make and model: Kicker L5 02S12L5 Dual Voice Coil 4 ohm
Subwoofer Size: 12
Number of Subwoofers: 2
Type of Port (Kerfed, Slot, Aero, etc.): Slot
What type of music do you like?: Hip Hop, Rock, Dubstep, Rap
Is your goal SPL or Everyday Music?: Mixture of Both?
Tuning Freq (Hz): 32hz
Volume : whatever is recommended
Comments: Recently bought these from a friend he didn't have manual so if someone could post a link to a manual that would be greatly appreciated. Would love a cut out sheet as well.
Would these Dimensions work? (I Used RE Audio Box Calculator)
Box Width: 40"
Box Height: 16"
Box Top Depth: 12"
Box Bottom Depth: 12"
Wood Thickness: 3/4 MDF
Square Port Height: 14.5"
Square Port Width: 2.5"
Square Port Length 1: 8.75"
Spuare Port Length 2: 13.25"
Total Port Length: 26.5"
Square Port Diameter: 6.79"
Square Port Area: 36.25"
Square Port Volume Internal: 960.625"
Box Volume: 2.827" Ft3
Box Volume: 4885.0625" In3
Tuned Frequency: 33.126"
2.8 cubes for the cone area of a pair of round 15's? Good luck, OP. IMO that's not an adequate box for one of those woofers.
Their 12's and their squares. Unless your talking about something else.
Sent from my LG-D851 using Tapatalk
15" round sub = appx 150 square inches.... 12" square sub = 144 square inches.
I just modeled the 12" L7 and they want 4-5 cube EACH to sound decent. I can't imagine L5 works well in a quarter of that space.
Oh ok you lost me there for a second. So 2 cubes for each sub would be more accurate correct?
xjake
xjake
San Antonio, TX
hispls
ThxOne
    May 25, 2026
