I appriciate the offer, but I want to build this one on my own //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I will be running XP pro 32 right now, and will have the choice to upgrade to 64 XP later on.
So that saves on the OS. One question...I noticed that the Mboard takes DDR2-1066 memory and the memory you linked was DDR2-800. Will that make a diff?
Memory speeds make a difference only if the processor will match up as well. Basically... memory speeds are only as fast as their weakest link. If the motherboard will handle a better speed, but the processor you utilize doens't support that threading, then it's useless to spend the extra money on a better speed of memory. If you like tho I'd be happy to discuss what I feel would be a great build for a system for you. Feel free to pm me or email me.
On second thought... I think I will post a few suggestions here along with my reasoning behind each component.
#1 Power supply. Always the most critical component in any system. If this is unstable or weak in any area your performance may lack, or worse yet, you can spend a lot of time in RMA on various parts of your computer. Of course an inexpensive and lesser quality or namebrand one may simply just die after a few months to a year. The corsair I've tested run incredibly solid. Much more so even than somme of the much nicer and more expensive power supplies on the market. They are also more affordable especially if you are looking at running two video cards.
#2 Video cards. I agree 100% witht he above post on the ATI video cards. The PCI-X 2.0 ATI 3800HD cards are so much more powerful and nicer than the nVidia cards and play much more friendly with motherboard selections for an AMD platform. The price... can't beat the price of ATI's highest end graphics card for under $300 when it runs better than the $500+ nVidia cards. (Keep in mind if you go with an INtel platform nVidia then has more perks)
#3 Motherboard. Spend the extra $ and go w/ an AM2+ motherboard. Always when you are building a system look at new and upcomming technologies and ensure that you are able to expand a good deal in the future. Even if you do not take full advantage of the higher HT counts and slightly more expensive processors, you will be able to do so later on down the road instead of having to replace a motherboard, processor and possibly memory.
#4 Memory. Reinstating what I said before about the price not outweighing the reward of the higher speeds. This is only true if you do not foresee an upgrade within a year or so. If, however, you are planning on doing a processor upgrade as more come available within the next year or so. Go ahead and spend the extra few bucks for the higher speed. If, though, you are not thinking that's very likely and want to stick to a tighter budget then stick w/ the 800mhz and you will be fine.
#5 Case. Always check out information for the cases thoroughly. Some look like they are pretty nice and good airflow, but in reality just do not perform like they should. Good brand names to stick with are Thermaltake, Coolermaster, Lian-Li. Features to look for in a case are "toolless" design. Aluminum cases as opposed to steel (steel cases tend to be a bit more heavy, resonate noise more and have some sharp edges that may be a pain to work around. Internal layout is important as well. Having plenty of room for proper wire routing is always nice (less wires hanging around in the case means better airflow and better system performance) Cases like the Thermaltake Armor are excellent for airflow, solid, and offer plenty of spare room for good wire routing. Coolermaster and Lian-li are also very well known for those features as well. Having the system a "toolless" design helps out greatly for any future swaps of drives and other parts.
Cases like the Antec you are looking at will have good airflow, but sacrifice noise levels for that airflow. The fans are not of very high quality and do make quite a racket running at capacity.
#6 Again if you are going to futureproof the system (and unless you are running autocad from a cpl yrs ago) I would recommend utilizing Windows Vista. yes lots of people complain about it, but... most have little real working experience in it and those that do, have either not run it on a new system, or simply were biased due to other sources complaints about it. Utilizing windows vista ultimate will allow you to expand your memory as you grow and won't cost you later on to get a legit copy of it. I run it on all of my systems personally and it's been fantastic. Windows XP Pro does have a few advantages, but it also has one major disadvantage. Windows Vista is the focus for most updates and such right now and being updated much more frequently than XP has been or will be. Support is also much more solid for the Vista platform as well right now. Your pick on the OS that's not a major ordeal just dropping my two cents there
As for your picks on your system. i'm not going to give any specific parts and prices, as that is your desicion, but I hope this helps a bit in giving the logic behidn the general recommendations I've made for you. Maybe even it will help some other enthusiasts here.
