Dead Pioneer Faceplate Display??
jhelmick
My son aquired a car from a family friend with a Pioneer DEH-P6700MP in dash unit, For some reason or another there is no working display on the faceplate, All the buttons are lit fine and they beep when pushed, Just no display.....or sound either. I suspect the faceplate is dead but who knows, is there anyone that has a schematic so I can test the faceplace pinouts to see if the unit may be the problem. Or any other recommendations short of buying a new faceplate or stero.
Thank You
i have the same problem with the pioneer unit in my truck, it comes on from time to time, usually more so in the summer. so i'd like to know how to fix this aswell.
most likely a bad ribbon cable...pioneer is bad about those going bad....
+2 on the ribbon cable....i had a kenwood with a flip around faceplate. After so many flips, the cable ribbon needed to be replaced. Once it was replace it worked fine. Problem is if you get a place to do it, they might charge you $70-$100, add another $100 and you could have a brand new unit.
It may be a non servicable resister embedded in the display itself. See the burn mark in the corner. Thats it.
Top right corner, Black burn mark on glass.
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
Normally I don't cheer players losing...but every since LeBron said he was the greatest ever...well...go nuggets 🤣🤣🤣
So, I had just picked up a Rockford Fosgate P300-2. A 2-channel amp. I had purchased it for 20$ knowing it wasn't working. But I was hoping it was...
jhelmick
jhelmick
Lincoln, NE
edzy
    May 24, 2024
    May 23, 2024
