dd rep's setup
talked to a dd rep @ modz distributing.... he said this setup would pound in a extra can pick up.... what do u guys think......
modz rep / tech..............My suggestion:
2 x DD1000 Series 12” SVC 4 ohms. Wired in parallel to give you a 2 ohm mono load.
Build a box 38” wide, 20” tall and 14” in depth out of 0.75 MDF with lots of triangle bracing, and cross wall bracing (I’ve oversized the box by 5% to accommodate lots of wood bracing)
The box must have a port of 8” x 8” (or equivalent) and must be 16” long.
Put the subwoofers facing upwards as well as the port.
Put a Digital Designs M1 amplifier to power the 2 subs.
That’s gonna be one killer sub system.
will it be... will it out match a single mtx 9500 12" with the same amp..... HELP!!!!
First of all, DD's are great subs but that series will not be louder than the MTX. If you went with like 2 3512d's in a big ported box then def. yeh! If i were you i would step up to 35 series or atleast 25 series. You will be alot more happy with those lines. Good luck and no matter what...you will love DD.
bigbassboi
Canada
pcnbaseball44
