DD 6.5 Box Help
One Bad MOFO
Turbo Fox
So I may be buying a car that I don't want a lot of extra weight in, so I don't want to do a huge system. I will probably only use my dd 6.5lt's. What I need to know is what kind of box should I put them in that would make them as loud as possible. Each would be on 150 watts.
Series
W6.5
Voice Coil Diameter
1.5"
Magnet Weight
28 oz
Power Handling RMS/Music/Peak
100/200/400
Suspension
25mm
Nominal Impedance
4.0 Ohm
DC Resistance
3.1 Ohm
Model
W6.5
Woofer Diameter
6.5"
Free Air Resonance
36 Hz
Qts
0.33
Qes
0.34
Qms
8.8
Vas
21 L
Le mH
Sensitivity
91 dB
Shipping Weight
11 lbs
they don't show the lt series on there any more so???
Well a t-line isn't going to give you huge output. A horn might work depending on your vehicle but the amount of wood is going to really weigh it down. Horns get real big, real fast when trying to tune them low.
This horn is tuned to 40hz and was for a single 6.5" driver:
thats kindof why i decided against the t-line. and yea that horn looks huge i don't think i want to do that. Would like an abc box work well at all?
id take my time and do a really good install with the 6.5s IN THE FRONT DOORS.
make sure theres no rattles (difficult), sperate front and back waves but leave o.b. and you will have very snappy and articulate bass / midbass down to about 40 hz, that can get very loud.
One Bad MOFO
Turbo Fox
One Bad MOFO
FÜCK Location
One Bad MOFO
