wilzyx 5,000+ posts
village idiot/racist
under $100? thats pretty cheap. you also make a good point, to the op: what amp is it? im from loomis btw.
Rocklin for me to be more specific. Pretty close. Im right near rocklin high school.under $100? thats pretty cheap. you also make a good point, to the op: what amp is it? im from loomis btw.
no one said not too? the only thing i would do is turn up the high pass if the his speakers are distorting with the lower bass. most coaxials cant reproduce freq's less than 60 or 80 hz very well.OK. I know people are going to bash me for this, but if you reduce the frequency response range, it will mean less overall quality and the sound will not be as clear, and since you say that you prefer clear music over loud music, my best advice is to keep the frequency response at its full range.
lol. The human range of hearing only goes up to 20 khz for the average person. Unless your making this system for your dog I'd say 30 khz is just one of their marketing gimmicks.AMP = Audiobahn A6004T Intake series A/B Mosfet amplifier. 75 x 4 @ 4 ohms.
First off I can tell when distortion comes up, it is obvious. I like to listen to clear music, NOT just loud music. I actually will probably get nowhere near full volume when it is all setup, I'm just trying to be safe.
Now, Is there a rule of thumb for speaker handling when it comes to response?
Such as, if my speaker can handle 30hZ to 35,000hZ, at full RMS, would I be smart to set the floor response to about 60hZ and the ceiling at about 30,000 hZ?
And for the crossover, it says that I can set for 0dB, -3dB, and -6dB. 0db has been described as safe for testing audio equipment, so would it be wise to set to 0dB?
You lost me. 30 khz is not audible by humans, but once it gets reflected all over the car it can be heard? Please elaborate. And how would these inaudible frequencies be recorded on the track in the first place? If its not a marketing gimmick what would be the point of advertising something that is completely useless?Joker, 30kHz is not a marketing gimmick. It is just the uppermost limit of a tweeter or a supertweeter on most speakers. Most speakers are rated for 30Hz to 30kHz. Since the sound in cars is reflected all over the interior of the car, most mid-range and high-range sounds will be somewhat distorted by those reflections, so even with the best equipment, the frequency range that is audible within an automobile is less than the full audible range of the human ear.
wtf man. I am calling bs. You are trying to tell me that road noise alters the frequency of a 30 khz tone to make it audible? Are you fvcking high or something?Joker, no, I am not saying that. What I am saying is this: The 30kHz signal is inaudible to humans, since the human ear can only hear sounds as high as 20kHz, but even that number is reduced by interference such as wind, road noise, and the way sound reflects inside a car. Most cars have a quiet ride, but they still get some wind noise, especially at highway speeds, and the sounds of the engine also take away from the full range of the sound inside the car. Even under optimal conditions, you would only be able to hear sounds between 30Hz and 15kHz inside a vehicle because of all the external interference. Custom "performance tuned" exhaust kits are not as quiet as factory-installed ones, so that adds to the noise inside the vehicle, further reducing the audible range of music. It is not necessarily the audible range that is being affected; actually, the signal-to-noise ratio is what is affected. Under optimal conditions, you will see at best 120dB signal to noise ratio, but because of all the external interference I just mentioned, you may only see a signal-to-noise ratio of 96dB or less. Based on my own personal experiences with computer audio equipment, I can say this: More often than not, the lower the signal-to-noise ratio, the lower the overall frequency response, though I know that is not always the case.
Have you tested the pre-outs with an oscope to make sure there is no clipping at volume 61/62? I would tend to suggest a lower number, to avoid pre out clipping and to be able to get full volume out of downloaded tracks that may have had a lower recording volume.Pioneer HU, set your gains @ volume 61/62 with ALL processing off!
