or set it the right wayWith midrange speakers i would just set the gains by ear. It is very easy to tell when midrange speakers begin to distort. At least much easier that woofers.
Pick a song that you know really well and turn the gain on your amp all the way down. Next set the h/u to the volume number that you would prefer to be your theoretical maximum. Usually about 3/4 to 7/8 of your h/u max. Then turn the gain up until your speakers start to distort. And thats it.
It's called damage control. Basically, he's letting people know that you're not a creditable source for information related to car audio. That way, there is less of a chance that people will damage their equipment via information from this forum.Squeak, if you are going to continue flaming me in other people's posts, then you obviously are not worthy of my attention, and therefore, you have no reason to speak to me.
no, it matters what volume the head unit is at when you set the gains. if you set the gains with the volume all the way up, then you can turn your hu all the way up and it wont clip.my HU is 22RMS*4ohms = 88/^2 = 9.4 gain?
so... that would make it bad to turn it past what volume?
very much the wrong way to do things just because you do not hear it does not mean the amp is not clipping. setting gains with a dmm may not be equal to the oscope method but it is definately better then your suggestionWith midrange speakers i would just set the gains by ear. It is very easy to tell when midrange speakers begin to distort. At least much easier that woofers.
but the HU will def clip at full volume //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifno, it matters what volume the head unit is at when you set the gains. if you set the gains with the volume all the way up, then you can turn your hu all the way up and it wont clip.
The right way would be with an o-scope. Not by assuming the manufacture has not overated or underated their amp. And I know it may be news to you but just because an amp claims so many watts it is rarely that. With my method (listening for distorion) at least you get the absolute most out of your amp.or set it the right way
Ive seen one on craigslist for under $100. Im from the roseville area. Im just trying to point out that by relying directly on the rated output by the manufacture you are making a large assumption on the honesty of the manufacture and the capability of your electrical system.well o scopes are hundreds off dollars while a dmm can be had for less than 20. also i noticed you are from sacramento, what area?
