cutting speaker holes
Got most of my box done just have to cut speaker holes. I was wanting to flush mount my subs but I already glued my second baffle piece to the front. How would I go about routing my holes so I can flush mount the subs?
I'll route your holes //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
Awkward ****** jokes aside, cut your first hole just a tad bigger (like 1/16") than the outside diameter of the sub, then the second hole the size of the cutout dimension.
I say just use a jig like this with a flat bottom bit and cut out your center ring then outside or visa versa. Your router should have a depth adjustment to take just enough of each baffel.
yep, if you have a plunge router, and a proper bit, and you haven't cut any holes yet - you can use the router to cut two holes. the first will be through the top layer and the outer dimension of the basket. once that is cut you set the router for the cutout dimension of the woofer and make those passes. the result will be a flush mounted woofer.
Generally speaking though MUCH easier to cut the holes if you haven't mounted the baffles yet //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif If your only doing a single cutout it's a non issue, but when it's a double baffle and I want to flush mount (always for me), then I cut first then put them in place.
You're probably right. I have two Taramps smart 3 amps and four 10 inch CT sounds tropo for bass. I'm actually going to only install one of the...
14
For me.. a compact amp that wouldnt take up a whole lot of room and not real expensive for a 350-600 rms sub@2ohms or even 1 ohm load id look at...
19
Restarting the phone every 1-2 days is a plus too. My moms phone is useless by the third day of not restarting. As soon as it's restarted it's fine.
961
gain set well below "Normal" and base boost is off completely
15
blowthemup
blowthemup
North Carolina
blowthemup
    May 23, 2024
SPLBassJunkie
    May 21, 2024
