Cutting speaker holes in door panels?
I used a jigsaw to cut the door metal behind my 10"s in my doors. Far from pretty but I don't really do anything pretty.
Good man! Thank you for the reply. My aftermarket speaker cutout diameter is 5.7 and the mounting hole mounting diameter is 6.2 so with just about 1/2 inch difference I can’t risk cutting into valuable door metal that I will need for proper speaker ring mounting integrity. 6.2 is coincidentally also the factory hole mounting diameter
You're probably right. I have two Taramps smart 3 amps and four 10 inch CT sounds tropo for bass. I'm actually going to only install one of the...
14
For me.. a compact amp that wouldnt take up a whole lot of room and not real expensive for a 350-600 rms sub@2ohms or even 1 ohm load id look at...
19
Restarting the phone every 1-2 days is a plus too. My moms phone is useless by the third day of not restarting. As soon as it's restarted it's fine.
849
gain set well below "Normal" and base boost is off completely
15
marvinwillis
marvinwillis
Hinesville GA
    Apr 28, 2024
    Apr 28, 2024
