Custom Atomic Apocalypse 12" For Customer
sundownz
Pro Seller
Supporting Vendor
SA-12 cone, spider, dust cap, coil + 4-spoke frame w/ 6.25 mm spacers
Atomic Apocalypse 2.5" Coil Motor
Going to measure T/S specs tomorrow
4 spoke baskets are nice but like you did you have to put a spacer in to aid cooling...
Not always, I have seen the 6 spoke version of those modified by a company to have cooling channels identical to those in the normal 12 spoke basket.
RE: 7.5 ohms
FS: 31.28 Hz
Qes: 0.546
Qms: 5.627
Qts: 0.498
Le: 7.03 mH
Vas: 29 L
BL: 26.6 N/A
Cms: 99 uM/N
Mms: 260 g
Motor strength is right on par with the actual SA-12 within a few %
It is still fresh, Fs should drop to 28 Hz or so with more play time //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The Cms is currently 99 uM/N and will settle closer to 140 uM/N (about 40% looser)
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
