Custom Mag v.3 15"
sundownz
Pro Seller
Supporting Vendor
Using Z15 cone / dust cap... 8-layer FW Dual-2 Coil @ 50mm WW... two hard nomex spiders w/ double leads.
I am going to measure specs once the dust cap glue dries.
Looks good, higher Qts. then I would have guessed.
I gained ~9% more motor force with the 8-layer coil but it is a good bit stiffer than the original... the original is around 140 uM/N and this is 80 uM/N but it is also only broken in for a few minutes.
This cone is also slightly heavier than the original.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
