Custom 15 Nice!
  • 5
funky waves
Custom 15 built with mostly TC Sounds parts
15" "TI" frame. TC9 motor with dual 1" slugs. 2.5" long coil, D2. TC "OEM10" type cone, very nice. Dual spiders. Solid Titanium Phase plug, yes titanium! 3" dia 5" long titanium, with 1.25" thick aluminum between it and the pole for heat sinking. No Gasket
Freshly assembled tested only.
Fs 34.3hz
Re 3.7(series)
Qms 4.8
Qes 0.72
Vas 60L
LE 3.3 mh
$400($350 without phase plug.) OBO +actual shipping.
Contact me for shipping costs
If you buy it without the phase plug all you have to do is glue on your own dustcap. Just FYI, in case anyone wonders the chunk of titanium alone is worth ~$400. It was some scrap I has laying around, and was just machining it for fun and ended up with a phase plug, lol.
To be honest I'm not sure Titanium actually isnt a very good conductor of heat, thats why I put a chunk of Aluminum in there to absorb the heat, so it shouldnt be too bad, but there is only one sure way to find out. That said I have fed it ~1.5kw for a min off and on to break it in a little befor pulling the Ts's, and it was fine, it didnt even get hot enough to give off that new coil smell.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
funky waves
funky waves
B.C. Canada
my_stealth21
    May 24, 2024
    May 23, 2024
