crx build complete,, pic;s and vids
i wanna see the back of the tube
im gonna take an off the wall guess and say there is an aeroport at the back side of the tube //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
btw ever heard of a router to cut circles? lol
dont have a rounter,, and there is a areo port in the back but you cant see it its inside the tube,, also its under the window line,, i gave it to all the word finals judges
if u get a router and make those rings look better. u could make that install look sweet with some fiberglass/fleece/resin.... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Im pretty sure that fails the string test ( over the window line )
String test is to see if anything is past the b-pillar. But you should try mounting the amp vertically between the 2 tubes and take the supports out from underneath the tubes if that makes sense.
noob? string test is also used to see if the box is above window line.
i tryed the amp in all possable ways to restrict the lease amount of air flow,, and it is under the window line the 6000 curves down on the sides the tubes are 12, then sitting on skid pads on the amp, ive competed this way alreay.. im getting a diffrent amp in about 2 weeks
loudaccent
loudaccent
long island
loudaccent
