crossover points??
You should be able to run your components down to 80Hz or so, unless you have 3" drivers //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And remember that crossover points are not brick walls - they attenuate down from the Xover point gradually, based on how steep (dB/oct) the Xover slope is set.
The mids are 5.25" drivers. Can you clarify more on how steep (db/oct) the xover slope is set. (my username says it) Thanks!
Sometimes it's variable (you can adjust it between different slopes), sometimes it's not (one fixed value).
The owner's manual should tell you whether or not you can adjust the slope, as well as the slope of the crossover. Probably 12db/oct, as that's what a majority of equipment is set at.
newb
newb
los angles, ca
squeak9798
NorthFramingham
    Jun 30, 2026
