Crossover help
  • 2
You can use just about any from Radio Shack to Coustic with good results, however I would recommend using a little better for possible expansion in the future as well as having greater flexability..Audio Control, Phoenix Gold, PPI, or something along those lines.
Mike
There's definitely quite a few that can give a better answer, but IMO, it's (1) 8" sub. It's supposed to be quicky and jabby, not a power...
7
For the front and rear speakers set the high-pass filter around 80-120 hz depending on what sounds better with over driving the speakers (you'll...
945
Agreed. I was actually thinking of building a 3-way passive and I compared the cost to a Dayton DSP and it makes no sense to go passive.
10
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
403
RavE
RavE
Oregon
mykeys
winkychevelle
    May 24, 2024
