Crossfire CFA202 questions and sub hookup
Bartak1
OK heres the deal. I have 2 Eclipse subs, only problem is one is a dvc 4 ohm one, and the other is a svc 4 ohm. So, I can only wire the DVC one for 2 or 8 ohms. Now, If i wired the dvc one to 2 ohms, then parallel wired the svc 4 ohm one to it, how many ohms would I have. Or is it a bad idea to do this? If I can wire them like that, would it be ok to wire them to a bridged CRossfire CFA202? My buddy has one that he jacked so he would pretty much give it to me. I cant find any info on the net about it, but it says 100x2 right on the amp. So also i was wondering if someone knew the specs for this amp, and if its a very good amp? Good compared to rockford amps.
THanks
Hold on, the vc's ARE getting wired in parallel on the DVC one. each vc is 4 ohms, so parallel wire them to get 2 ohms, then parallel wire that sub to the svc 4 ohm. So that would be 2, or 1.33
What if I series wire the dvc one(8 ohms) and parallel wire the svc 4 ohm one to it?
Thanks a million
dayum my mistake lbx i misunderstood the question--you were right 2 ohm but if you wire the vc's together in parallel ...well you get the idea. just slap me.
//content.invisioncic.com/y282845/emoticons/ready2go.gif.6557fa3d88b9eaca9c7b8efb9cbd02ed.gif :readytog: //content.invisioncic.com/y282845/emoticons/ready2go.gif.6557fa3d88b9eaca9c7b8efb9cbd02ed.gif :readytog: //content.invisioncic.com/y282845/emoticons/ready2go.gif.6557fa3d88b9eaca9c7b8efb9cbd02ed.gif
2 ohms
Bartak1
Bartak1
Nebraska
LBX2G
