FRIEK
its been 20 years since i was into good car audio equipment,and my system needs a boost bass wise. so much has changed as have companies.
ive found this amp JBL BP1200.1 amp and just waiting to make payment, i got it for $175 off a differant forum.
sub is picked out,but id like recomendations if i can find better under $300?
Alpine SWX-1243D 12"
ill be running that one sub with 1200w rms,and im pretty sure i want it in a sealed box.either ordered or i build it.
im not so sure on reading what specs alpine is calling for,but here is the pdf with all the info: http://support.alpine-usa.com/products/documents/OM_SWX-1243D.PDF
scroll down a bit and its in english.
i cant tell if it should be 1cf or 3 cf?
i like this combo as it should hit hard but not be boomy and have good SQ,i tried to match the amp and sub perfectly.but ive read the sub will handle more than 1000rms
the amp is 600 watts rms at 4 ohm, 1200 watts at 2 ohm, and is not recommended to be used at 1 ohm,but wont do it as 2ohm is fine for me.
as i said the amp is a done deal,subs are just picked out but can switch to something better as long as its under $300.
i can build my own box,but id rather not.
this looks fitting and the price is right: http://cgi.ebay.com/12%22-ALPINE-TYPE-X-Sealed-Subwoofer-Box-Sub-Enclosure_W0QQitemZ300308774971QQcmdZViewItemQQimsxZ20090419?IMSfp=TL090419153009r15132
thoughts?suggestions?
