CRD Mazda CX-7 SQ Install
A little update on the midranges, I have the kick panel sanwiched between the midrange and midarange bezel, I will reduce the ring of the bezel at work using a lathe, I will reduced to the diamater of the 4 screws. just like the first pic marked in green
Here is a design I'm working for the amp rack , I still need to design the sides to cover the wires and a plexi glass in front and top to show the amps with a blue neon light. This is only the design of the main frame.
This is the final setup, I know it will last 1-2 months installed before I decide to change the equipment , but for now this is what I'm going to install this weekend. I will post pictures of the process.
Yeah baby!!!
I finally finish the bezel, now I need to put some primer+sand, black paint+sand, black paint + more sanding. and wallaaa
Tomorrow is going to be a busy day //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I had to re-design the previous amp rack , because I erased the autocad file by mistake and lost all the measurements, so I did a simple design. The amp rack will sit on the center of the trunk with (1) 10" sub on each side. More pictures when finsih the other stuff //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Here is another update, I also labeled my wires //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif and finish all the wiring on the speakers.
Very nice setup! I would love to take a listen to that.
Also Peel and seal isn't as bad as people make it out to be. If you take your time and clean first and heat it up, it will stay.
Good job and look foward to the finished product.
Today I received my new Daytons 8" Subwoofers to replace the 7" ones I have. I'm making the baffles tomorrow. I have everything ready to install I just need time, and I'm still in the process of moving //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
YES //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Finally have the main piece of the puzzle done, without it I couldn't install the system. In my opinion I give the piece a 8.5 out of 10 but looks good in day light.
8" LCD Touchscreen PC Monitor fused into the scoche double din kit for my cx-7.
Now is time to choose the program I will use "front end" and look for a good sound card either PCMCIA or PCI don't know yet wich one I will use if my motherboard or laptop. I will test first with the laptop.
More pics, I still have space for a Widescreen 9.2" touchscreen, but I need to find one with good brightness
Kicker 46CSS654 CS Series 6-1/2" component speaker system chose these for the front chanel Kicker 46CSC654 CS Series 6-1/2" 2-way car speakers...
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
458
CRD
CRD
Orlando, FL
nitro_freak1
audiobaun
    May 19, 2024
    May 19, 2024
