CRD Mazda CX-7 SQ Install
A little update on the midranges, I have the kick panel sanwiched between the midrange and midarange bezel, I will reduce the ring of the bezel at work using a lathe, I will reduced to the diamater of the 4 screws. just like the first pic marked in green
Here is a design I'm working for the amp rack , I still need to design the sides to cover the wires and a plexi glass in front and top to show the amps with a blue neon light. This is only the design of the main frame.
This is the final setup, I know it will last 1-2 months installed before I decide to change the equipment , but for now this is what I'm going to install this weekend. I will post pictures of the process.
Yeah baby!!!
I finally finish the bezel, now I need to put some primer+sand, black paint+sand, black paint + more sanding. and wallaaa
Tomorrow is going to be a busy day //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I had to re-design the previous amp rack , because I erased the autocad file by mistake and lost all the measurements, so I did a simple design. The amp rack will sit on the center of the trunk with (1) 10" sub on each side. More pictures when finsih the other stuff //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Here is another update, I also labeled my wires //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif and finish all the wiring on the speakers.
Today I received my new Daytons 8" Subwoofers to replace the 7" ones I have. I'm making the baffles tomorrow. I have everything ready to install I just need time, and I'm still in the process of moving //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
YES //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Finally have the main piece of the puzzle done, without it I couldn't install the system. In my opinion I give the piece a 8.5 out of 10 but looks good in day light.
8" LCD Touchscreen PC Monitor fused into the scoche double din kit for my cx-7.
Now is time to choose the program I will use "front end" and look for a good sound card either PCMCIA or PCI don't know yet wich one I will use if my motherboard or laptop. I will test first with the laptop.
CRD
CRD
Orlando, FL
nitro_freak1
