Couple of questions
Ok, i have two amplifiers
jl 1000/1 and a Digital Designs m1 original
I have a single digital designs 12" DD 2512 dvc 4 0hm wired at 2 ohm.
My question is, every time i look up ratings for the dd m1, it lists for 4 ohm and 1 ohm, but no 2 ohm rating. Are these good for 2 ohm? if so, does anyone know the power rating?
Second, Which amp would be best suited to my sub?
Im going to sell the one that i dont use
any idea on value on the m1 original and the jl 1000/1?
here is a pic of the amps to prove im not just a troll daydreaming about car audio
it is designed for 2ohm load. just guessing on rating but I would look for a rating of about 400w @ 2ohm.
However these were extremely underrated and ive seen many clamp them at 1kw+ at 1 ohm
If any amp is rated at 1ohm, 2ohm, ect it will do anything higher. They show a 4ohm rating because that's what some competitions base class off of. In this case I would use the JL but it is old, I would keep the M1 as a back up. On a 2ohm load the JL makes way more power but it's also VERY power hungry, it's not going to like stock electrical.
Tom82
Tom82
British Columbia, Canada
LosIsATool
