could someone calculate this tuning?
Lil Poot
you sturrin at me brah?
need to know what this box is tuned to please. subs will displace .4 cubes each.
Ok total volume before port displacement is --------13.828125 cubic feet.
Total volume port displacement is ----------------------1.215 cubic feet
Total volume displaced by subs is-------------------------.8 cubic feet
Total volume after displacement is --------------------11.812 cubic feet
Tuning Frequency is---------------------------------------44Hz
hmm... the box designer says its 38 hz, and another designer says 44 hz. i'm confused //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Looks to me that he calculated it with gross volume and not net volume. If he used 13.828 cubic feet then thats why it is 38Hz. You would have to make the port 17.36 inches long for it to be tuned to 38Hz
that says i should use a width/height ratio of less than 1:8 and wont calculate it for me //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Invert the numbers and override and you get 39hz, seems pretty dead on. It gives ratio suggestions to avoid port noise.
Using that same calculator you used and entering in 39Hz for tuning is not correct
Volume---------------- 11.812 cubic feet
Tuning------------------39HZ
Number of ports------1
Type of port-----------Square
Slot port----------------Yes
Port Height-------------4.5"
Port Width--------------40"
Port Length------------13.68"
By the pic the port height after wood thickness subtraction is 3.75'', correct?
I know the picture looks confusing but if you look at it you will see a double dimention line on the bottom indacating that he is not measuring from the bottom of the box but the bottom of the port opening.
Lil Poot
Lil Poot
Wichita KS
Lil Poot
BP1Fanatic
BP1Fanatic
